alexworld83
I described a RAM in verilog, and in the top level I instantiated 8 block of the same RAM. I have to initialize them by a different set of data... so I want to use the command "readmemb" at top level but I don't know the correct syntax or if this is possible
---------RAM code-----------
module ram_64B(clk, en, write_en, data_in, data_add, data_out); input clk, en, write_en; input [7:0] data_in; input [5:0] data_add; output [7:0] data_out; parameter RAM_WIDTH = 8; parameter RAM_ADDR_BITS = 6; //(* RAM_STYLE="{AUTO | BLOCK | BLOCK_POWER1 | BLOCK_POWER2}" *) reg [RAM_WIDTH-1:0] ram [(2**RAM_ADDR_BITS)-1:0]; reg [RAM_WIDTH-1:0] data_out;
wire [RAM_ADDR_BITS-1:0] data_add; wire [RAM_WIDTH-1:0] data_in; always @(negedge clk) if (en) begin if (write_en) begin ram[data_add] <= data_in; data_out <= data_in; end else data_out <= ram[data_add]; end endmodule
---------Top level-------------------
ram_64B tm_filt1 (clk, en_ram, 1'b0, data_in_tm_filt1, data_add_tm, data_tm_filt1); ram_64B tm_filt2 (clk, en_ram, 1'b0, data_in_tm_filt2, data_add_tm, data_tm_filt2); ram_64B tm_filt3 (clk, en_ram, 1'b0, data_in_tm_filt3, data_add_tm, data_tm_filt3); ram_64B tm_filt4 (clk, en_ram, 1'b0, data_in_tm_filt4, data_add_tm, data_tm_filt4); ram_64B tm_filt5 (clk, en_ram, 1'b0, data_in_tm_filt5, data_add_tm, data_tm_filt5); ram_64B tm_filt6 (clk, en_ram, 1'b0, data_in_tm_filt6, data_add_tm, data_tm_filt6); ram_64B tm_filt7 (clk, en_ram, 1'b0, data_in_tm_filt7, data_add_tm, data_tm_filt7); ram_64B tm_filt8 (clk, en_ram, 1'b0, data_in_tm_filt8, data_add_tm, data_tm_filt8);
Thank you
