Aug 16th, 2024, 7:51pm
Output of a sine wave  generator is 0. (Read 1813 times)
zahrein
Oct 05th, 2011, 1:53am
HI ,
Im trying to model  a sin wave generator. And seems nothing is  out  from the  waveform. Copied my testbench and verilog. Do give me your opinion. Appreciate a lot. Thanks
Testbench
module tb_test_ver();   //testbench  module  name
wire  pina, pinb;    // declaring wire input
sine_wave out2(.wave(pinb));
initial $vcdpluson;  //log on vpd file for dve
initial      #(50000000000) $finish;  //set to run for 50,000ps
Verilog code  for  sine wave generator
module  sine_wave (wave);
output wave;
real offset;
electrical wave;
parameter real freq   = 1000 from (0:inf);
parameter real ampl= 1;
analog begin
  V(wave) <+ ampl * sin(3.142* freq * $abstime);
  $bound_step(0.05/freq);
boe
Re: Output of a sine wave  generator is 0.
Reply #1 - Oct 6th, 2011, 3:46am
Hi zahrein,
your sine generator seems OK to me. Note that it runs with 500 Hz, so 50 ns is not very much.
Are you sure that $vcdpluson supports electrical signals?
B O E
PS: Which simulator do you use?
« Last Edit: Oct 6th, 2011, 6:46am by boe »
zahrein
Reply #2 - Oct 6th, 2011, 6:36pm
Yes, Boe. Thanks for explaining the mistakes. I fix my  verilog and it can can run.
Heres the code. And im running on DVE, this is a part of the  VCS  system at my company.
output wave;
real offset;
electrical wave;
parameter real freq   = 1G;
analog begin
  $bound_step(0.00001/freq);
Reply #3 - Oct 6th, 2011, 8:48pm
Your $bound_step() will force the analog kernel to take 100K points per cycle, which is absurd. You'd be much better served using $bound_step(0.1/freq).
boe
Reply #4 - Oct 7th, 2011, 1:20am
Zahrein,
Note that in the analog section of Verilog-AMS code the units are given in the include file disciplines.vams, usually Volt, Ampere, second, .... And the timescale directive has no effect for the analog stuff.
This is the reason for the $bound_step issue Ken pointed out.
B O E
Reply #5 - Oct 7th, 2011, 7:38am
pi is 3.142 ??   Ugh.
Why not use `M_PI from
`include "constants.vams"
boe
Reply #6 - Oct 7th, 2011, 8:39am
BTW, it should be 2π (`M_TWO_PI).
-B O E
zahrein
Reply #7 - Oct 8th, 2011, 1:43am
HI Boe &  Geoffrey_Coram & ken,
Thanks  for  pointing out. The reason i  did  not  use the constant M_PI is  to  check  my code.  I increase the bound step  is    to check wether it has  an impact on my sine wave or not as my  sine wave look not so  smooth. I thought by increasing the bound step will make my sine wave to be smoother.
Thanks...
