Aug 16th, 2024, 7:53pm
RAM initialize!!! (Read 497 times)
alexworld83
RAM initialize!!!
Oct 10th, 2011, 10:39am
I described a RAM in verilog, and in the top level I instantiated 8 block of the same RAM. I have to initialize them by a different set of data... so I want to use the command "readmemb" at top level but I don't know the correct syntax or if this is possible
---------RAM code-----------
module ram_64B(clk, en, write_en, data_in, data_add, data_out);
     input clk, en, write_en;
     input [7:0] data_in;
     input [5:0] data_add;
     output [7:0] data_out;
     parameter RAM_WIDTH = 8;
  parameter RAM_ADDR_BITS = 6;
  //(* RAM_STYLE="{AUTO | BLOCK |  BLOCK_POWER1 | BLOCK_POWER2}" *)
  reg [RAM_WIDTH-1:0] ram [(2**RAM_ADDR_BITS)-1:0];
  reg [RAM_WIDTH-1:0] data_out;
  wire [RAM_ADDR_BITS-1:0] data_add;
  wire [RAM_WIDTH-1:0] data_in;
  always @(negedge clk)
     if (en)
           begin
        if (write_en) begin
           ram[data_add] <= data_in;
           data_out <= data_in;
        else
           data_out <= ram[data_add];
---------Top level-------------------
ram_64B tm_filt1 (clk, en_ram, 1'b0, data_in_tm_filt1, data_add_tm, data_tm_filt1);
ram_64B tm_filt2 (clk, en_ram, 1'b0, data_in_tm_filt2, data_add_tm, data_tm_filt2);
ram_64B tm_filt3 (clk, en_ram, 1'b0, data_in_tm_filt3, data_add_tm, data_tm_filt3);
ram_64B tm_filt4 (clk, en_ram, 1'b0, data_in_tm_filt4, data_add_tm, data_tm_filt4);
ram_64B tm_filt5 (clk, en_ram, 1'b0, data_in_tm_filt5, data_add_tm, data_tm_filt5);
ram_64B tm_filt6 (clk, en_ram, 1'b0, data_in_tm_filt6, data_add_tm, data_tm_filt6);
ram_64B tm_filt7 (clk, en_ram, 1'b0, data_in_tm_filt7, data_add_tm, data_tm_filt7);
ram_64B tm_filt8 (clk, en_ram, 1'b0, data_in_tm_filt8, data_add_tm, data_tm_filt8);
Thank you
Re: RAM initialize!!!
Reply #1 - Oct 14th, 2011, 6:57am
    [1] I don't know the reason why you have to initialize RAM block. Do you want to prevent from any X state in the simulation?
    [2] I don't see any readmemb in your code.
    [3] Assume you have verilog simulator, try to compile it and the simulator would tell you if there is any syntax error.
