Jul 22nd, 2024, 12:35am
How to use multi CPU with ams (Read 9958 times)
Kamal
Oct 11th, 2011, 1:34am
I would like to know how to use multi cpu with ams-ade.
I use UltraSim as solver.
K.
boe
Re: How to use multi CPU with ams
Reply #1 - Oct 12th, 2011, 3:28am
Kamal,
Versions?
There is a HIgh Performance options sub menu in the ADE setup menu, where you should be able to change the multi-threading settings (IC 5.1.41).
B O E
Kamal
Reply #2 - Oct 13th, 2011, 7:21am
The only way I found to have a faster simulation is to decrease the accuracy of the simulation (Simulation->Options->FastSPICE(UltraSim)->Speed Option->Accuracy).
K.
Reply #3 - Oct 14th, 2011, 7:12am
Kamal,
Version?
Select Setup --> High-Performance Simulation and a form pops up. Then select Turbo or APS, both having Multithreading options.
Yawei
Kamal
Reply #4 - Oct 20th, 2011, 7:16am
I am using IC 5141, there no "High-Performance Simulation"  item in the "setup" menue.
K.
boe
Reply #5 - Oct 20th, 2011, 9:41am
Kamal,
recent versions of IC5.1.41 have it.
- B O E
Reply #6 - Oct 20th, 2011, 6:46pm
Hi Kamal,
What is your IC.5.1.41 version? And beside IC5.1.41, you need mmsim to enable High-performance simulation, otherwise that item is grey in Setup menu.
Yawei
Kamal
Reply #7 - Oct 21st, 2011, 2:41am
Hi Ywgo,
my IC version is 514USR5 & mmsim seems loaded:
*MMSIM (71) loaded*
K.
ywguo wrote on Oct 20th, 2011, 6:46pm:
Hi Kamal,
Yawei
boe
Reply #8 - Oct 21st, 2011, 4:07am
Hi Kamal,Kamal wrote on Oct 21st, 2011, 2:41am:
Hi Ywgo,
*MMSIM (71) loaded*
K.
IC5.1.41usr5 is far too old. Update to a recent version. And MMSIM7.x is quite old, too. Also a candidate for an update.
- B O E
Kamal
Reply #9 - Oct 21st, 2011, 5:50am
Ok, thanks for you answers.
K.
boe wrote on Oct 21st, 2011, 4:07am:
Hi Ywgo,
*MMSIM (71) loaded*
K.
- B O E
Coles
Ridgehill Dr Brampton, ON
Reply #10 - Nov 8th, 2011, 1:11am
I was using IC5.1.41 on my system but now I want to upgrade the 6.1.3 version.
Please,can you give me some help about how to set the environment  for doing so..
View Profile colesruff colesruff   IP Logged
