ethanlinear
I am confused with isj_out. It is not on the port list and never has an initial value, but there is a line,
vsj_out == vsj_int + isj_out * 50.0;
What is the purpose for isj_out here? I am trying to convert VHDL-AMS code into Verilog-AMS code, how can I do it? thanks,
architecture bhv of sj_src is constant sj_tau : time := 10ps; quantity vsj_out across isj_out through sj_out; quantity vsj_int : voltage; begin -- All quantities considered in a 50 Ohm environment -- Voltage source is 2 * effective voltage -- sj_amp is considered a PP voltage -- output signal is centered around Vdd/2=0.0V vsj_int == 2.0 * (0.0 + 0.9 * 0.5 * sj_amp * sin(MATH_2_PI*sj_freq*freq*NOW)); vsj_out == vsj_int + isj_out * 50.0; end bhv;
