Jul 27th, 2024, 7:44am
Question on VHDL-AMS modeling? (Read 2517 times)
ethanlinear
Oct 11th, 2011, 11:14am
I am confused with isj_out. It is not on the port list and never has an initial value, but there is a line,
     vsj_out == vsj_int + isj_out * 50.0;
What is the purpose for isj_out here? I am trying to convert VHDL-AMS code into Verilog-AMS code, how can I do it? thanks,
architecture bhv of sj_src is
     constant sj_tau : time := 10ps;
     quantity vsj_out across isj_out through sj_out;
     quantity vsj_int : voltage;
begin
     -- All quantities considered in a 50 Ohm environment
     -- Voltage source is 2 * effective voltage
     -- sj_amp is considered a PP voltage
     -- output signal is centered around Vdd/2=0.0V
     vsj_int == 2.0 * (0.0 + 0.9 * 0.5 * sj_amp * sin(MATH_2_PI*sj_freq*freq*NOW));
end bhv;
Re: Question on VHDL-AMS modeling?
Reply #1 - Oct 11th, 2011, 9:26pm
isj_out appears to the the current through sj_out.  Looks like the voltage source in series with a 50Ω resistor.
