Aug 1st, 2024, 11:27pm
Calculation of sampling cap. (Read 2115 times)
medya
Oct 14th, 2011, 2:45pm
hi,
I am designing  a pipeline ADC and   using this formula for calculating sampling cap(for front end S/H):
(LSB)^2/12=KT/c   ===>  c>=12*2^(2N)*KT/Vfs^2
because of vfs is the differential value then the calculated value for csample=2*c
is that true???
my ? is that when we calculate csample for pipeline ADC we neglect  from other stages thermal noise because of their noise attenuated by preceding  stages  but first mdac noise does not attenuated  as the front end S/H gain is 1 in this case  must we add its noise to noise of the S/H????
and doubled the csample??
can any one introduce a good references for calculating noise in SC circuits???I search in google but not find any ref that explain it well.
thanks.
carlgrace
Berkeley, CA
Re: Calculation of sampling cap.
Reply #1 - Oct 16th, 2011, 7:48pm
Yes, you need to take the noise in the first mdac into account.  The way to do that is to notice the noise of the first stage and the SHA add as sum of squares, so if you size your SHA sampling cap the same as the first stage you will have a 3dB increase of noise.
Look for Boris Murmann's notes for Stanford ee315B.  They are excellent.
