raja.cedt
hello, without adding compensation cap, it is very difficult to compensate unless you are ready to compromise some thing, for example your second pole is at drain of the Q5, so there try to reduce the cap otherwise try to increase the cap. By the way whats the load cap, try to increase that it will be compensated. Whats the CMFB architecture?
Thanks, raj.
