Dec 13th, 2025, 6:13am
frequency analysis of ADC (Read 5427 times)
singh
Oct 21st, 2011, 1:51am
ineed to plot gain curve for the transfer function,
to see frequency response, we need to keep input fix suppose vin =1 and vary the frequency. and then get the corresponding output
now i get say output vector and input vector,
Suppose i have out vector B and input vector A with (j-1) rows
i calculate TF as :
TF = fft(B,j-1)./ fft(A,j-1);
now in order to plot magnitide plot ... is it ok to do mag = abs(TF) ??
please suggest regarding this
Re: frequency analysis of ADC
Reply #1 - Oct 21st, 2011, 6:02am
you are taking the FFT of a nonlinear circuit?
does not make sense
singh
Reply #2 - Oct 21st, 2011, 6:59am
hmm ya its a mistake..
i plot phase vs digital out code for specific input value .
and now i want to take rms of the digital out obtained for the phase o to 2pi
how can i do that
Reply #3 - Oct 23rd, 2011, 7:37pm
Phase of what to what?
Please clarify what the question is.
singh
Reply #4 - Oct 24th, 2011, 3:12am
i want to see plot of rms value of digital output code Vs frequency
my digital out code is a function of input ,frquency  and phase
I keep input value same as vin =1,
for different frequencies, I am getting output digital codes by varying phase from 0 to 2pi
suppose for freq = 1 to 10
                  for phase 0 to 2pi
                    get output = f(phase,frequncy,input)
                    out"(i) = output
                    rms = (out(i)) ???????
now i want to take rms values of different output codes obtained by varying phase from 0 to 2 pi in each frequnecy.how to caluclate rms value to know the output power spectrum.(whichi s i guess rms value Vs frequency)
Reply #5 - Oct 24th, 2011, 5:40am
Singh,
  You probably need to start at the beginning, that is, by telling
people what you want to do. Basically, you can not analyze an ADC
using small signal techniques. The approach I have seen most often
is to make many measurements or run many simulations, each at a
different frequency and then plot the result vs. input frequency. You
can repeat the process for different input levels if you would like but
usually you just run that tests near the maximum input level. Next
question, why do you think that phase is effecting the response of
the ADC?
singh
Reply #6 - Oct 24th, 2011, 6:45am
vref is 3V so i m trying at amplitude as 2.5V. my input is sinusoidal (frequncy ,phase) so i wanted to see the effect of changing phase value on the output code.
so therefore,
                 for phase 0 to 2pi
                   get output = f(input=f(fre,phase))
                   out"(i) = output
Reply #7 - Oct 24th, 2011, 3:19pm
Below is a good suggestion. In addition:
1. Give us a picture or block diagram of what you are trying to do.
You mention changing the phase.
Changing to phase of what?
The input signal to the clock?
Describe a specific problem, and we can try to help.
sheldon wrote on Oct 24th, 2011, 5:40am:
Singh,
the ADC?
