Sep 4th, 2024, 5:27am
Pages: 1 2
Finding zero in an amplifier (Read 8915 times)
buddypoor
Bremen, Germany
Re: Finding zero in an amplifier
Reply #15 - Oct 30th, 2011, 2:22am
Hi raj,
At first, I completely agree with Ricky's explanation.
Secondly, there may be some confusion using the term "zero".
Therefore, I'll try to give my explanation:
Taking your simple example H(s)=(1+sRC)/D(s).
This is a transfer function with the complex variable s. I have added a time constant RC due to consistency in units.
At s=-1/RC there is a zero, which means that the transfer function output is zero at this "point" (it is not a frequency!).
It is simply the negative real part of s.
This property of H(s) cannot be measured (it is just a mathematical fiction) because one cannot produce a "frequency" which is a negative constant.
Referring to measurements, we can, however,transfer H(s) into a frequency response A(jw) by simply replacing s by jw.
And we can ask ourself: What can be measured at a "frequency" that equals the above given "zero": w=1/RC ?
As a result, we can compute the magnitude (and phase) for A(jw) and
we see that at this frequency the BODE diagram exhibits a change in the slope.
Thus, we can conclude that H(s) exhibits a zero at a certain value for the variable s (in our case negative-real). If we, however, interpret this variable as a frequency we see that the frequency response (Bode diagram) at this point changes the slope.
The point of confusion is that in both cases we speak of a "zero frequency".
Unfortunately, Razavi is not consistent because on page 176 this zero is called "wz" and on page 177 he uses "sz". Thus, on page 176 he implicitely referres to A(jw) and on page 177 he referres to H(s).
A similar case exists, of course, for poles. We speak of pole frequencies, thereby knowing that the magnitude of A(jw) goes not up to infinity.  This can be observed only in the 3D-plot for H(s).
________________
Ricky Chen
Reply #16 - Oct 30th, 2011, 5:33am
Let us say if you have (s+1)/(den), then zero will be at -1+(j*0) means there is sinusoidal signal frequency which can give you 0 gain
The above statement is WRONG. You can't have a sine wave which have ZERO o/p for this T.F.
raja.cedt
Reply #17 - Oct 30th, 2011, 5:50am
hello Ricky Chen
i mean to say that there is no sin signal which gives zero gain..it's a typo.
raj.
buddypoor
Bremen, Germany
Reply #18 - Oct 30th, 2011, 6:09am
Hi Ricky and Raj,
in addition to my comments above I like to point to the following:
The frequency response A(jw) of a circuit shows a slope change at frequencies that correspond with singularities (zeros/poles) of H(s) in the s-domain.
And this fact demonstrates the usefulness of the s-domain. This can be part of the answer to the question (that very often can be read): What is the purpose and the advantage of introducing the complex frequency s ?
Pages: 1 2
