Jul 17th, 2024, 5:33pm
Question Listing 19 Chapter 4 Bidirectional Connect Module (Read 3881 times)
Marcelo Baru
Oct 27th, 2011, 5:01pm
Can someone explain me the line:
always @ (vstate or istate or d) begin
   case (vstate)
I am not sure I fully understand vstate or istate or d. vstate is an integer.
I hope to have more luck than with me skin effect question.
Marcelo
Re: Question Listing 19 Chapter 4 Bidirectional Connect Module
Reply #1 - Oct 27th, 2011, 5:11pm
You are in luck. The '@(vstate or istate or d)" triggers if there are any events (i.e. changes in) vstate, istate, or d. Thus, whenever one of those variables changes, the case statement is re-evaluated.
Marcelo Baru
Reply #2 - Oct 28th, 2011, 1:24pm
Many thanks Ken. You confirmed my thought. I wish there was a better explanation of the OR operation.
Cheers,
Marcelo
Marcelo Baru
Reply #3 - Oct 28th, 2011, 1:34pm
Ken,
In the same listing, shouldn't always @(above(V(a)-vl, 1)) inXrange =1; be a cross function? Or the 1 removed? The posedge condition is checked below.
BTW is there a link to submit errata info for the book?.
Marcelo
« Last Edit: Oct 28th, 2011, 2:52pm by Marcelo Baru »
Reply #4 - Oct 28th, 2011, 6:58pm
Marcelo,
   Yes, you should delete the 1 in @(above(V(a)-vl, 1)). Thanks for the comments on the book, I have recorded them so when I do the second edition I will resolve them. If you have any further comments or want to point out errors, just send them to me.
Marcelo Baru
Reply #5 - Oct 28th, 2011, 10:07pm
Great Ken. I will collect them once I finish reading the book and I will let you know.
Best,
Marcelo
