Aug 16th, 2024, 10:17pm
AC simulation of dynamically biased  opamp: pss pac in spectre (Read 1927 times)
mixed_signal
Oct 27th, 2011, 10:43pm
I am designing a dynamically biased amplifier shown below. In biasing phase, switch phi (bottom)is closed and switch phibar (top) is open and  amplifier is not in use. In amplifying phase, it is the opposite and it amplifies.
I want to do AC analysis to find UGB and DC gain. I want to do the simulation with the switches included. How can I do that? How in AC simulation, switches work which is transient activity?
Is it  possible to simulate with the switches included?
I have heard of something like pss and pac in Spectre. I am using spectre ( not Spectre RF). Pls provide tutorials for pss and pac in spectre. I have kens paper. Pls provide a concise tutorial.
Pls provide alternate solution if it exists.
Thanks Smiley
raja.cedt
Re: AC simulation of dynamically biased  opamp: pss pac in spectre
Reply #1 - Nov 7th, 2011, 5:48am
hello
you can find spectre document here
http://www.stwing.upenn.edu/~sbattle/cadence_doc.pdf
Raj.
