Sep 4th, 2024, 1:18pm
Pages: 1 2
Common Mode Feedback Contorl (Read 4658 times)
rajkumar palwai
Sunnyvale, California
Re: Common Mode Feedback Contorl
Reply #15 - Nov 01st, 2011, 4:15am
Praveen,
any leakage path at the gate of M7 will take the steady state node voltage to the extremes eventually and hence the circuit doesn't work.
Ricky Chen
Reply #16 - Nov 1st, 2011, 4:22am
rajkumar palwai wrote on Nov 1st, 2011, 4:15am:
Praveen,
Rajkumar,
That is why there is a refresh cycle in Switch cap CMFB circuits.
The circuit by the way is the snap-shot of one state of Switch cap CMFB circuit. So DC -ve f/B does EXIST in the above circuit !!
rajkumar palwai
Reply #17 - Nov 1st, 2011, 4:23am
I mean, at the steady state the average value of the M7 gate voltage would be either '0' or 'vdd' depending on whether the leakage to gnd is strong or leakage to vdd is strong.
U can simulate a simple example case. Put 2 caps in series and give 2 transient signals at the 2 ends. Then connect a big resistor (eg:1e12) at the centre node to gnd/vdd to model the leakage and see the o/p waveforms.
rajkumar palwai
Reply #18 - Nov 1st, 2011, 4:25am
Ricky,
yaa. it wil work in switch cap cmfb ckts, where we periodically refresh the charge.
But i thought praveen was asking about the DC cap feedback circuit and expalining that.
Ricky Chen
Reply #19 - Nov 1st, 2011, 4:28am
rajkumar palwai wrote on Nov 1st, 2011, 4:23am:
You did NOT understand what I mean to say.
What do you think the leakage impedance will be ?? Will it be such that it will leak the sizable amount of charge from the CAP before the refresh cycle ??
if that you think, then probably switch-CAP circuit would NOT have existed !!
Cheesy
rajkumar palwai
Reply #20 - Nov 1st, 2011, 6:59am
Ricky,
I do know how a switched cap CMFB works and i designed pipelined ADC's using that.
In my previous post i was just explaining a case when there is no refresh cycle at-all i.e when u connect the fdbk caps just like that and dont refresh them for ever.
I hope u understand.
Reply #21 - Nov 1st, 2011, 3:53pm
Ricky Chen wrote on Oct 31st, 2011, 11:58pm:
SWITCH CAP  CMFB circuit.
By the way the above circuits are the snapshot of one state of SWITCH CAP sense circuit
None of us can read minds.
You never said anything before about this.
Please define your probably correctly in the
future, and do not assume we have the capability
read your mind from the other side of the planet.
My mind reading capabilities are limited to under a 300km range.
Cheesy
raja.cedt
Reply #22 - Nov 2nd, 2011, 12:59am
hello wave,
how does current source solve start up problem here?
raj.
Ricky Chen
Reply #23 - Nov 2nd, 2011, 2:10am
loose-electron wrote on Nov 1st, 2011, 3:53pm:
Cheesy
Hello Loose-Electron
After knowing that it is a switch-cap CMFB, do you have any answer to my question ? How DC f/b is NOT in the circuit ?
Sorry for trying to read people's mind.
Thanks for letting the forum know about your reading CAPABILITY
Lex
Eindhoven, Holland
Reply #24 - Nov 2nd, 2011, 2:31am
Funny thread with all those cheesy smileys  :D.
Both structures have their advantages. The one without the DC bias can be advantageous if you want to spare on biasing circuits/routing. The one with DC will probably have better start up behavior, less leakage problems, better (large signal) common mode rejection and so on.
Ricky Chen
Reply #25 - Nov 2nd, 2011, 2:38am
Lex wrote on Nov 2nd, 2011, 2:31am:
thanks a Lot !! Alexander
Can you please explain why it will have better (large signal) common mode rejection ?
You may point to any literature which actually explains this large signal CM behavior in CMFB circuit
Reply #26 - Nov 2nd, 2011, 6:49pm
The circuit that only control part of the common mode is preferred in my opinion.
With only partial amounts of the current under control, you will be less likely to create wide erratic behavior ion the common mode signal.
One circuit can fully turn the bias current on/pff, the other one can adjust things up-down in a smaller amount.
RobG
Bozeman, MT
Reply #27 - Nov 3rd, 2011, 2:21pm
Maybe Ricky should change his chance his avatar to Wilma so I can tell him from loose e- (as in loose e, I'm home).
I don't know a ton about cap cmfb, but the circuits I've seen switch both sides of the cap to reference points during a reset cycle. This allows a voltage drop across the caps to the fb device and the CM output to be biased at any level desired. If resistors were used there would be no DC drop and the either the fb device or the diff pair would be linear except within a very small range of input common mode bias with this particular topology. (Although a dc current could be injected at node P to level shift the output common mode level.)
You'd like the FB device to supply only a small current to keep the common mode gain small, especially for increased stability (IE the parallel DC tail source supplies most of the current). The danger of this is that if mismatches cause the parallel DC tail current to be more than the PMOS currents the fb device will be completely off and the output will be pulled low.
Low CMFB gain also means the common mode output will deviate a larger amount from ideal since the FB device will need more gate drive to make up for mismatched tail/load currents.
addendum... I'm pretty sure this circuit is meant to be reset as opposed to using resistances. The resistances are not needed: one could use simply use two NMOS FB devices: both drains tied to the tail, and the first/second gates tied to the left/right outputs respectively.
Reply #28 - Nov 6th, 2011, 5:33am
Ricky:
You really need to ask the question in a better fashion.
If the circuit is a switched capacitor system, you need to show all states and switches.
Acquisition phase, zero out phase, control phase - whatever you got.
Thing is you can get a switched cap system to deal with CMFB and all that put you need to show whats going on in all phases and control points of your switching.
If the system is run switch cap and includes proper zero and precharge of all capacitors, it can work properly. For something like that, a fixed DC current on the bias is NOT wanted, because then it injects a leakage effect that causes the control voltages on the capacitors to discharge/droop.
Ask your question again with a better definition of the problem.
Pages: 1 2
