Aug 1st, 2024, 7:17am
no metastability problem in comparator at lower frequencies (Read 4179 times)
seenu
guwahati
Nov 01st, 2011, 9:49am
  when iam using this dynamic comparator with equal inputs  iam not getting metastability state for the given circuit for different values of (W/L) ,,,,but metastability occuring only when the enable frequency is higher i.e is in Ghz range.
   Why i didnt get the metastability problem for low frequencies
Can anybody suggest me the solution ?
Thanks in Advance
srinu
boe
Re: no metastability problem in comparator at lower frequencies
Reply #1 - Nov 1st, 2011, 12:35pm
Did you use same rise/fall times for the signals? Did you consider the delay of the comparator? Simulator (accuracy) settings may depend on things like sim end time...
- B O E
wave
Reply #2 - Nov 1st, 2011, 6:25pm
How are you simulating metastability?
Are you just looking at gross failures?   Noise analysis?
Reply #3 - Nov 5th, 2011, 1:04pm
metastability is usually an issue with small inputs where the circuit does not have enough gain to make the device take one state or the other.
more info needed...
Vladislav D
The Netherlands
Reply #4 - Dec 10th, 2011, 3:47am
First, you should understand for yourself what metastability is. I'd define it as an event when a comparator cannot resolve the input within particular amount of time .
Secondly, metastability is a probability-thing, i.e it occurs always! At high frequency, comparator has less time to resolve input and so you see a lot of metastable events. However, it is very difficult to see metastability issue at low frequency because probability is much-much lower.
Reply #5 - Dec 10th, 2011, 10:11am
Vladislav D wrote on Dec 10th, 2011, 3:47am:
Agreed - and add to that - higher frequency = less gain.
one perspective is time domain and the other is frequency. Both are valid.
