Sep 4th, 2024, 7:17pm
divider self oscilation frequency (Read 3542 times)
raja.cedt
Nov 06th, 2011, 1:42am
hello all,
I have implimented high frequency Bicmos static divider (working @ 100GHz), it is working in transient but i want to simulate self-oscilation frequency of the oscilator, so i just biased the clock input, without appling the clock signal but i haven't seens oscilations. Can any one suggest me what the problem (my latch is working fine). I thought of posting schematic but it's a common CML master and slave flip-flop.
Raj.
Re: divider self oscilation frequency
Reply #1 - Nov 6th, 2011, 5:20am
Inject some noise into the system.
In a simulation no noise unless you define it.
No noise and most oscillators will sit at a center bias point.
raja.cedt
Reply #2 - Nov 6th, 2011, 5:32am
hello  loose-electron,
yes you are correct, i used to keep some intial condition for oscilations by default.
Raj.
Reply #3 - Nov 6th, 2011, 5:35am
happy to help
raja.cedt
Reply #4 - Nov 12th, 2011, 9:46am
hello loos-electron,
I did PSS for the divider, it showing 30GHz. Did you observe this any time, in transient it is not working with a stimulus..any guess on this?
Raj.
Reply #5 - Nov 14th, 2011, 10:06am
would need to know more specifics about your circuit, test conditions and simulation setup
