Sep 4th, 2024, 5:16pm
Group Delay (Read 1002 times)
summi
Group Delay
Nov 08th, 2011, 3:54am
Dear forum,
Can any one please explain what is group delay clearly. Up to my knoeledge it represent delay of the signal and if i have constant group delay then there is no phase distortion
Br,
Summi.
Re: Group Delay
Reply #1 - Nov 8th, 2011, 4:05am
buddypoor
Bremen, Germany
Re: Group Delay
Reply #2 - Nov 8th, 2011, 4:18am
Loose-electron gave you a link, which contains good information on group delay.
I like to emphasize the fact that group delay is NOT simply "the delay of a signal". It is rather the delay of a group of sinusoidal signals, which are relativ close to another in frequency (bandwidth small against the average frequency). Think of a signal that is amplitude modulated. In this case, the ENVELOPE is delayed by a time value that is identical to the group delay.
Remark: It is surprising but the group delay also can be negative!
(Example: Notch filter).
raja.cedt
Re: Group Delay
Reply #3 - Nov 8th, 2011, 5:58am
hello buddypoor,
what is the meaning of -ve group delay?
raj.
buddypoor
Bremen, Germany
Re: Group Delay
Reply #4 - Nov 8th, 2011, 6:51am
raja.cedt wrote on Nov 8th, 2011, 5:58am:
hello buddypoor,
raj.
Hi Raj,
as you know - group delay is defined as the negative slope of the phase-vs-frequency response.
That means: If you have a system with a positive slope of this kind the resulting group delay is negative (and also the group velocity).
What does it mean? According to its definition the information (e.g. envelope of an AM signal) is available at the output before it appears at the input. Sounds surprising - but it is the truth and has been prooved by several experiments.
