Jul 17th, 2024, 3:31pm
exponential delay on/off transition? (Read 2743 times)
niikos
Nov 08th, 2011, 7:34am
Hi everyone,
I would like to apply an exponential time delay to an current source that i model using verilog-a using Cadence.
I would like something like the transition operator but with emponential delay not a linear.
One more thing is that I want the on time delay to be different than the off time delay.
I have tried to implement this using RC network, but the network messes up the function of the circuit in time slots it supposed not to.
Any other idea?
boe
Re: exponential delay on/off transition?
Reply #1 - Nov 11th, 2011, 8:25am
Niikos,
Try decoupling from the load.
If you need more help, I suggest you post your code.
- B O E
niikos
Reply #2 - Nov 12th, 2011, 4:15am
this is what i did. thanks
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Reply #3 - Nov 13th, 2011, 1:03pm
To get a proper time domain behavior that looks like a exponential rise/fall you need to make sure you get enough time points. The best way to achieve this is by using the $bound_step system task. If you use a linear rise from the transition operator as input and just map the linear value to the equivalent exponential value you should be able to calculate arguments to the $bound_step task that control the step size to be sufficiently small during transition while switching off this step size control when it has reached its final value.
Cheers,
Marq
