Sep 5th, 2024, 11:22pm
Inductive Peaking (Read 1441 times)
summi
Inductive Peaking
Nov 10th, 2011, 9:35am
Dear Forum,
Can any one please tell me on what basis we have to choose inductor value in a peaking amplifier? There are some value's of 'm' in books, Which one is the best for design.
Br,
Summi.
raja.cedt
Re: Inductive Peaking
Reply #1 - Nov 10th, 2011, 10:26am
Please note that you have to describe your question, for example some prople may not be femilier with m, i guess it will be R*R*C/L.
So coming to your Question it depends on the application, for example if you want to design pulse amplifiers, you have to chose inductor in such a way that m=3.1, for max BandWidth it should be 1.41. You find can more details in TH lee book.
Raj.
summi
Reply #2 - Nov 10th, 2011, 10:35am
Dear Raja.cedt,
thanks for your reply. What is the max BW we can achive with the inductive peaking, is there any limit on that?
Br,
Summi.
raja.cedt
Reply #3 - Nov 10th, 2011, 10:45am
hello,
without peaking, you can use 1.41 as i explained in the previous post. but you can get more BW but you have to compremise on peaking in magnitude responce. But accodring to bode integral max BW you can 2 times (accoring to theory) than without inductor case.
I forgot where i read this concept, otherwise i would have given the reply.
Raj.
Reply #4 - Nov 10th, 2011, 11:03am
get a more detailed model of the inductors with parasitics in the models.
This limits the "good" frequency range of the inductor.
In a similar manner, get a model for the capacitor as well.
using those you can determine an LC that will work properly at the frequency of interest.
Harry Poll
7326 Bluestone Rd, San Antonio
Reply #5 - Nov 26th, 2011, 2:04am
There are several new inductive-peaking techniques for bandwidth enhancement of low-voltage CMOS current amplifiers. The techniques improve the bandwidth by utilizing the resonance characteristics of LC network by employing bond wire capacitance or on-chip spiral inductors. Both series-peaking and shunt-peaking techniques are considered.
View Profile HarryPoll HarryPoll   IP Logged
raja.cedt
Reply #6 - Nov 26th, 2011, 10:06am
hello Harry poll,
i am more intersted to learn new techniques, i know seris, shunt and bridge T..any new thing apart from there? and what do you mean by current amplifiers?
raj.
