Jul 17th, 2024, 4:23pm
Verilog-A vs Verilog-AMS (Read 9585 times)
tky86
malaysia
Nov 10th, 2011, 7:26pm
I'm not sure whether i post in the right place or not. I was wondering what is the different between verilog-A and verilog-AMS?
Could i get the free-download either these 2 tools in any websites?
Thanks.
boe
Re: Verilog-A vs Verilog-AMS
Reply #1 - Nov 11th, 2011, 8:13am
tky86,
Verilog-A is for analog models. Verilog-AMS supports digital as well.
- B O E
Reply #2 - Nov 14th, 2011, 8:56am
Verilog-AMS  (analog and mixed-signal) is a hardware description language.  Verilog-A is the analog-only subset of V-AMS.
They're languages, not tools.  There are some free tools that support some parts of Verilog-A (qucs and ADMS, for example, both on sourceforge.net).
tky86
malaysia
Reply #3 - Nov 17th, 2011, 5:04pm
thanks!
which tools can support verilog-A/ verilog-AMS? any free download website?
thanks
Reply #4 - Nov 22nd, 2011, 10:39am
Did you read my previous response?
Geoffrey_Coram wrote on Nov 14th, 2011, 8:56am:
afridi
Reply #5 - Feb 7th, 2012, 10:04pm
In reference to this topics... a question arises that my Cadence shows a Verilog-AMS type cell but when I write any code it doesn't compile, whereas Verilog-A works.
What could be the reason?
The more things you do, the more you can do.(Lucille Ball)
boe
Reply #6 - Feb 8th, 2012, 4:27am
afridi wrote on Feb 7th, 2012, 10:04pm:
Are the required tools installed? Do you have the licenses needed?
- B O E
afridi
Reply #7 - Feb 8th, 2012, 5:04am
how can one check this from the CIW?
I am a student so I don't know exactly what kind of licenses are installed.
All i know is that Spectre Version is 5.10
boe
Reply #8 - Feb 8th, 2012, 5:28am
Afridi,
Spectre 5.1.0 is very old. You should use Spectre 10.x/11.x (from MMSIM10/11). For AMS you also need INCISIVE (was IUS), which should not be too old either.
Try ncsim -W for version of IUS/INCISIVE.
- B O E
afridi
Reply #9 - Feb 8th, 2012, 6:48am
Dear boe,
If the AMS is so old why is there an option of VerilogAMS-Editor in the cellview?
The ncsim -W doesnt work in the CIW.
It shows the following error
" *Error* eval: undefined function - ncsim "
boe
Reply #10 - Feb 8th, 2012, 7:11am
Afridi,
sorry, I forgot to mention that you should run the command in the shell.
Older versions of the tools should support AMS as well, but you should expect more problems.
- B O E
boe
Reply #11 - Feb 8th, 2012, 7:13am
afridi wrote on Feb 8th, 2012, 6:48am:
IMO it is Cadence marketing stategy to show fetures you have not licensed...
- B O E
