Jul 17th, 2024, 7:41am
Limiting amplifier (Read 2572 times)
henrytqy
Limiting amplifier
Nov 13th, 2011, 6:00am
Hi dear all,
Recently I read some papers about limiting amplifer, but I'am not fully understand it. In RF design we often heard about PA,mixer,LNA. Why do we seldom heard of LA?
Can someone explain what's the limiting amplifier used for in the RF circuit? In what situation that we need it?
Thanks lot~~
raja.cedt
Re: Limiting amplifier
Reply #1 - Nov 13th, 2011, 6:21am
hello,
there is no speciality about limiting amplifier(LA)..it's normal amplifier (with out any gain control to prevent saturation fro large signals) which is generally operate in small signal input regime. In general you will find LA in the baseband to amplify the week signal. There is another amplifer called AGC which is also LA with soma gain control mechanism to avoid saturation by redusing the gain in the presence of large signal.
Hope this helps.
raj.
aaron_do
Reply #2 - Nov 13th, 2011, 5:11pm
limiting amplifiers can be used in baseband as raja.cedt pointed out. They are useful for constant envelope modulated signals in that they can amplify your signal up to a specified amplitude like in an AGC, but much faster since there is no loop. So in other words they are immune to sudden changes in the signal amplitude.
regards,
Aaron
Reply #3 - Nov 14th, 2011, 10:03am
Limiting amplifiers - two classes of these that I know of -
Amplifiers that are design to reduce gain as input signals get larger coming in. (as mentioned here)
Amplifiers with a fixed gain, used in cascade within a log-amp structure.
