aaron_do
He is asking how to characterize IIP3 for capacitive loads, not 50 ohm...
IIP3 is input referred. Therefore, the input is a power level. You can take the input power which causes the IM3 (voltage) to equal the fundamental voltage. If you want an output referred value, you need to look at a voltage level.
regards, Aaron
