Aug 17th, 2024, 4:19am
How to measure duty cycle in cadence ADE? (Read 6781 times)
Daniel Lai
Taipei
Nov 16th, 2011, 5:38pm
May someone advice me how to measure the duty-cycle of waveform in IC5.1 Analog Design Environment? I would like to calculate the duty cycle of several waveform with several corners, and some function script in ADE calculator would be much helpful.
Daniel
Re: How to measure duty cycle in cadence ADE?
Reply #1 - Nov 21st, 2011, 1:40am
The calculator has two functions named dutycycle and dutycycles if it is in MDL mode. Please run wavescan using the following command.
wavescan -expr MDL &
BG
Yawei
Daniel Lai
Taipei
Reply #2 - Nov 21st, 2011, 2:10am
Hi Yawei,
Thanks for your advice, it works fine and solves my problem.
Kind regards,
Daniel
