Aug 17th, 2024, 2:18am
Op Amp Input Capacitance (Read 4489 times)
sunnysunnyho
Oct 05th, 2011, 12:26pm
I am doing a analogue project at the moment.
I am trying to simulate an op-amp using Pspice. Well, Cadence Allegro
to be exact. And I am trying to find the *input* *capacitance* of an op-amp. (power supplies, +ve and -ve inputs and output)
What should I do? How can I find it. Which sort of simulations (or even components on the schematic) I would need?
Cheers guys, I really help you help Smiley
buddypoor
Bremen, Germany
Re: Op Amp Input Capacitance
Reply #1 - Oct 5th, 2011, 12:58pm
Because you must operate the opamp in open-loop condition, at first you have to find the offset voltage Vo in order to bias the opamp in the linear region. After applying Vo you can feed an ac voltage Vac in one of the inputs and simulate the current vs. frequency (ac analysis).
Then display Vac/Iac. This function gives the input impedance and looks like a first order lowpass. From the cutoff frequency (3 dB) you can derive the input capacitance of the model (if any - some models are pure resistive).
raja.cedt
Reply #2 - Oct 6th, 2011, 1:33am
otherwise you can find  S-parameter.
raj.
Daniel Lai
Taipei
Reply #3 - Nov 16th, 2011, 5:50pm
To get the impedance (real part+imaginary part), you may use AC or SP (S-parameter) simulation to do it.
For example at AC:
1. Apply the DC voltage
2. Input an AC voltage source at OPAMP Input
3. Measure the AC current of voltage source output or OPAMP input
4. Zin=Vin/Iin, and result is a complex (Z=R+jX)
weber8722
Reply #4 - Nov 17th, 2011, 8:15am
Look up Cheesy: The differential input C and the one measured single-ende or the common-mode C might be different! Usually Cdiif is biggest and more nonlinear than the others.
