Aug 1st, 2024, 1:26pm
why passive adder are sensitive to itself parasitic capacitance in DT SDM (Read 5422 times)
lawrence.W
Nov 18th, 2011, 2:15am
hi, all
I just figue out the passive adder is affected by comparator input node parasitic capacitor. The comparator input node voltage is attenated.
But some papers write passive adder are sensitive to itself parasitic capacitance. I am not clear what is mean. Am I missing something more important to consider?
thanks a lot!
L.W
raja.cedt
Re: why passive adder are sensitive to itself parasitic capacitance in DT SDM
Reply #1 - Nov 18th, 2011, 2:57am
hello,
could you elobarate more, it's difficult to get answers for this kind of Questions, please attach some related stuff if posb.
raj.
lawrence.W
Reply #2 - Nov 18th, 2011, 5:40am
Hi, raj
Thanks for your reply.
The attached is schematic. The capacitor adder is made of C1, C2,C3. Cp is parasitic cap of quantier that attenuates the quantizer input voltage. I am not clear the capacitor adder's parasitic caps effect. As I consider, the bottom plate parasitic caps of C1, C2,C3 are not big deal. The top plate parasitic caps also attenuate the quantizer input voltage just like Cp. Am I missing other issue about these parasitic caps?
L.W
Reply #3 - Nov 18th, 2011, 9:41am
The circuit shown will have problems with parasitics as part of the capacitors, and the switches also not being ideal, (Both RC time constants and charge losses through the parasitics of the switches.)
Plus noise issues, but I suspect the RC  parasitics and non ideal switches will be the big problem.
THe devices will work , but they have limitations.
lawrence.W
Reply #4 - Nov 18th, 2011, 7:14pm
hi. loose-electron
thanks for your reply.
As your reply , RC parasitics is problem. But the problem  puzzling me is whether capacitor adder parasitics has same effect as Cp for charge loss if switch is ideal. Can I consider these capacitor adder parasitics as Cp. Then the autozer can be applied to reduce the Cp and capacitor adder parasitics effect.
thanks
L.W
Reply #5 - Nov 19th, 2011, 5:55pm
What is Cp?
What is the "autosizer" that you mention?
lawrence.W
Reply #6 - Nov 20th, 2011, 7:38pm
hi,
the Cp is quantizer input node parastic cap. the autozero can be applied to the comparator to reduce offset.
thanks
L.W
Reply #7 - Nov 21st, 2011, 2:11pm
ok, understood -
suggest making the circuit such that when it "zero's out" that the decision circuit at the end be fed back around itself so that it precharges the Cp, as shown in red in your drawing, to the switching point. That way your adder circuit only has to determine above/below the trip point of the non-linear decision element.
From what I can tell you are just trying to do a summation such that you determine if you are above-below a decision point, correct?
