Sep 6th, 2024, 3:21am
Basic Curent Conveyor (CCII) operation (Read 5065 times)
ssp
Nov 24th, 2011, 2:42pm
Hi everyone,
I have been bothered by the operation of the following  second-generation current conveyor (CCII). In this case it decharges the capacity (arrow points the current direction of the current source). Althought, as I'm new to the integrated circuit world, I have difficulty analysing the behaviour of this circuit, and seeing what's the exact purpose of the OTA amplifier.
Also, what should be the caracteristics of the OTA and why ? (ie. high gain?, large output swing ?..) ?
Thanks for your help,
ssp
buddypoor
Bremen, Germany
Re: Basic Curent Conveyor (CCII) operation
Reply #1 - Nov 25th, 2011, 12:44am
Hi ssp, who has told you that the shown circuit is a CCII ?
That's not true.
A current conveyor has one (non-invertnig) high-resistance and one (inverting) low-resistive input. The last one acts as a current input - contrary to OTA properties. This current is internally "conveyed" to the output and appears there (mostly with a factor of unity) as an output current.
ssp
Reply #2 - Nov 25th, 2011, 11:21am
Hi buddypoor,
thanks for your response.
Actually, I see the caracteristics of a CCII in that circuit:
Y = non-invertnig, high-resistance
X = invertnig, low-resistance
Z = current input, high resistance
buddypoor
Bremen, Germany
Reply #3 - Nov 25th, 2011, 11:42am
ssp wrote on Nov 25th, 2011, 11:21am:
Hi buddypoor,
But that's not an OTA ! An OTA has two high-impedance inputs !
ssp
Reply #4 - Nov 25th, 2011, 12:54pm
Right....
but I guess that if the current source injects a very small current, let's say 1 nA, it can fit practically for both the requierements of OTA and the CCII ? This circuit comes from the following article and seems to work until the current source applied is 200 nA:
Narula and al. A time-based VLSI potentiostat for ion current measurements:http://ieeexplore.ieee.org/search/freesrchabstract.jsp?tp=&arnumber=1608062&open...
They don't give the details about the operation of the CCII as they call it.
buddypoor
Bremen, Germany
Reply #5 - Nov 26th, 2011, 1:08am
My only concern was the shown OTA symbol in connection with the term "CCII". If the shown circuit is able to work or not is another question I did not touch at all.
(By the way: I have no chance to open the IEEE document).
Vladislav D
The Netherlands
Reply #6 - Dec 1st, 2011, 10:36am
This circuit does not make sense. You confuse symbols of voltage and current sources
Reply #7 - Dec 1st, 2011, 2:18pm
Vladislav D wrote on Dec 1st, 2011, 10:36am:
Agreed - the circuit as drawn needs to be fixed.
Please give a better description of what you are trying to do or trying to understand.
You got a current source with a ground at each end.
Does not compute!
RobG
Bozeman, MT
Reply #8 - Dec 1st, 2011, 6:56pm
ssp wrote on Nov 25th, 2011, 12:54pm:
Right....
No, the size of the current doesn't matter - the input stages are completely different by definition.
