Aug 15th, 2024, 7:24am
Simulator for treating reciprocal mixing correctly? (Read 3616 times)
weber8722
Nov 25th, 2011, 5:39am
many modern harmonic balance simulators can treat circuit with both VCO and mixers correctly. So doing a noise analysis you should see the noise transfer from LO phase-noise due reciprocal mixing if a blocker is present at the RF port. I found it correctly in simulations, but only for fix-LO generator (with phase-noise), NOT for a real VCO circuit.
Ken Kundert mentioned in a great 1999 paper that many HB simulators cannot fully simulate noise correct in such cases with VCO+mixer, but now we have 2011....
What is the state of the art?
Bye Stephan
Re: Simulator for treating reciprocal mixing correctly?
Reply #1 - Nov 26th, 2011, 5:30pm
Stephan,
  The issue is not the phase noise calculation. The issue is how do you
calculate the steady-state of a system that includes both driven, Mixer,
and autonomous, VCO, components. The solution has been available
for several years, semi-autonomous HB analysis. Spectre/APS RF's
semi-autonomous HB analysis will calculate the steady-state of a
mixed-systems, that is, circuits containing both autonomous and
driven components. This approach also addresses the issue of how
to simulate the effect of power supply noise on a VCO.
                                                           Hope this helps,
weber8722
Reply #2 - Dec 2nd, 2011, 5:13am
Hi Sheldon, thanks for your response, but let me clarify some things...
sheldon wrote on Nov 26th, 2011, 5:30pm:
Stephan,
driven components...
                                                           Hope this helps,
The problem is NOT to run an HB analysis on vco+mixer, the result from this is fine Smiley. The problem is the HB-noise analysis on top of this! You can easily simulate the NF increase of the whole receiver using HB-noise, but it works only correct in simulators like spectrerf for fix-LO (with same phase-noise of course, driven mode), i.e. having no VCO circuit. Transient noise gives me consistent output noise in both cases. So there is no testbench problem.
I have never seen a science paper really showcasing reciprocal mixing simulation in HB, with true cross-check to tran-noise or well-known reciprocal mixing formulas. Do you know any? Smiley
Bye Stephan
