chandu28 wrote on Nov 30th, 2011, 9:17pm:actually this is the schematic of a 1 row DRAM design each block is working individually starting from the top sense amplifier,isolation circuit , cells(row of cells) write driver circuit refresh circuit and at he end column decoder...
we know that the main problem in any design is the connections to various blocks i dunno where the mistake is... thats what is my question sir...
OK, then suggest you start by using the blocks to build and simulate as you build parts of the schematic until the response is not as expected.
Divide the problem and understand it as you go.
Also, if you think there is an unexpected loading effect someplace you may want to either monitor currents in connections, or insert ideal voltage to voltage buffers in lines to determine where the loading problem is.
