Jul 31st, 2024, 5:32am
Pages: 1 2 3
DRAM DESIGN (Read 23335 times)
chandu28
vellore
Re: DRAM DESIGN
Reply #15 - Dec 06th, 2011, 10:46pm
I found out the error sir ... its the decoder which I have used... its giving 2v output when I give 11 as input and nearly 1 for other 3 inputs.... can you suggest me some which can give equal outputs???  :) Smiley Smiley
and also the swing is too low please see the pictures
chandu28
vellore
Re: DRAM DESIGN
Reply #16 - Dec 6th, 2011, 10:46pm
this is another example... can you please suggest some methods????
Re: DRAM DESIGN
Reply #17 - Dec 7th, 2011, 9:42am
Is the fault in the circuit, or due to the load on the circuiit. (see prior suggestion on buffers to isolate)
start there.
chandu28
vellore
Re: DRAM DESIGN
Reply #18 - Dec 9th, 2011, 3:26am
sir I have used a 2 inverter connected back to back kind of sense amplifier which is somehow acting as an inverter.... any suggestions????
Re: DRAM DESIGN
Reply #19 - Dec 9th, 2011, 5:50pm
The output of the inverter is probably attenuating the signal, the two devices ar both trying to pull the node in different directions. The result is attenuation or voltage division depending on the size of the transistor involved.
chandu28
vellore
Re: DRAM DESIGN
Reply #20 - Dec 9th, 2011, 8:49pm
so how can I reduce it sir??? its effect is more than loading effect.... do I have to vary the transistor sizes???
Re: DRAM DESIGN
Reply #21 - Dec 10th, 2011, 10:15am
Which device do you want to provide the most signal?
That one should use bigger W/L transistors.
Usually 2 inverter latch structures have small W/L devices so another device with bigger W/L transistors can flip the latch back and forth.
chandu28
vellore
Re: DRAM DESIGN
Reply #22 - Dec 10th, 2011, 8:39pm
sir I am generally considering PMOS as a base...
I think since I am not using the output of the bitline bar only one side of the latch is being used and hence it is acting as an inverter... am I correct sir???
If so how can I proceed further sir???
Re: DRAM DESIGN
Reply #23 - Dec 12th, 2011, 12:19pm
Back to back inverters will act like an SR latch, if you
drive the device properly.
It is a memory device with the driver removed.
When one side or the other is forced high-low the inverters function as inverters.
chandu28
vellore
Re: DRAM DESIGN
Reply #24 - Dec 27th, 2011, 5:31am
yes sir it does..
I have another doubt sir .... now how can I convert it to sdram....we know we can do this by adding clock to the system... my question is how exactly.... can you please through some light on it.
awaiting your reply..
sincerely,
M.S.Chandra Sekhar Smiley
Re: DRAM DESIGN
Reply #25 - Dec 27th, 2011, 1:09pm
You really need to do some research and reading on this subject.
http://technav.ieee.org/tag/8571/sdram
http://en.wikipedia.org/wiki/Static_random-access_memory
http://ieeexplore.ieee.org/Xplore/login.jsp?url=/iel5/4/4317684/04317699.pdf?arn...
Start there. Also search for vendors who
make SDRAM chips and read their documentation.
chandu28
vellore
Re: DRAM DESIGN
Reply #26 - Jan 6th, 2012, 1:13am
thank you sir....
sir,can I redraw sense amplifier as shown in the picture.....theoretically it should work well but practically it isn't can you through some light here.
sincerely,
M.S.Chandra Sekhar
Re: DRAM DESIGN
Reply #27 - Jan 6th, 2012, 1:41pm
The sense amplifier that you have may not have the needed gain, it is a single logic inverter.
More gain, and a way of matching the center null point
(average of Vmax, Vmin) of the holding cell to gin amplifier are needed.
Maybe 3 inverters in series would be sufficient, perhaps a comparator
amplifier structure could be considered.
raja.cedt
Re: DRAM DESIGN
Reply #28 - Jan 6th, 2012, 2:12pm
hello loose-electron,
i guess you need gain otherwise it takes more time regenerate.
Raj.
Re: DRAM DESIGN
Reply #29 - Jan 8th, 2012, 1:30pm
raja.cedt wrote on Jan 6th, 2012, 2:12pm:
Raj.
Not sure what the OP is looking for here.
Help when you can right?
Pages: 1 2 3
