Jul 31st, 2024, 5:19am
Pages: 1 2 3
DRAM DESIGN (Read 23322 times)
chandu28
vellore
Re: DRAM DESIGN
Reply #30 - Jan 09th, 2012, 9:26pm
thank you sir for the links they very informative.....:)
now the question is how to get the hardware form...
from the information i gathered, i can draw an FSM or write a code in C or Verilog...but how to get it to hardware form....means circuit diagram sir....
Sincerely,
M.S.Chandra Sekhar.
chandu28
vellore
Re: DRAM DESIGN
Reply #31 - Jan 27th, 2012, 9:01am
hello sir,
            i have an idea like writing a code for sdram controller,after that synthesizing the code which gives me a schematic...
i will redesign the schematic and connect it to the main diagram....
will that work??? Smiley Undecided
awaiting your reply...
sincerely M.SChandra Sekhar
chandu28
vellore
Re: DRAM DESIGN
Reply #32 - Feb 2nd, 2012, 8:33pm
Hello sir
           I have simulated a code in Xilinx ISE and synthesized it too. after that I got two schematics RTL and technology .... If I want to use the schematic for another circuit in mentor graphics which one to use????
awaiting your reply,
sincerely ,
M.S.Chandra Sekhar
Re: DRAM DESIGN
Reply #33 - Feb 11th, 2012, 5:22pm
It is very difficult to answer questions on things that should be found by your efforts in textbooks, published papers, applications notes and guidelines to using design tools.
Reads the manuals on the design tools, search the internet for information on transporting designs between design tools. If you have a target design platform you are going to make something on, ask the supporters of that platform how to use it and how to transport designs into it.
All of these things are part of being a design engineer.
chandu28
vellore
Re: DRAM DESIGN
Reply #34 - Feb 11th, 2012, 7:47pm
Thank you sir Smiley Smiley
sincerely
M.S.Chandra Sekhar
Pages: 1 2 3
