Jul 17th, 2024, 4:16pm
Variable optimizer via verilog-ams? (Read 1479 times)
weber8722
Dec 02nd, 2011, 3:16am
Hi, verilog-a or verilog-ams allow programming of measurement modules or state-machines to set a bus to obtain a desired output value (like 1V+-10mV). The later can be done with a simple sweep or via succ. approx. Good applications would be doing a circuit calibration, etc. Such techniques are also very similar to mathematical optimization algorithms (like gradient optimizers). Spectremdl features such simple optimizer, but is something like that also available in verilog-a/ams??  :D SmileyWould be helpful to have such a module esp. if it can treat multiple variables, because then a simple sweep to check all combinations is often far too time-consuming.  :(
Bye Stephan
