Hi, verilog-a or verilog-ams allow programming of measurement modules or state-machines to set a bus to obtain a desired output value (like 1V+-10mV). The later can be done with a simple sweep or via succ. approx. Good applications would be doing a circuit calibration, etc. Such techniques are also very similar to mathematical optimization algorithms (like gradient optimizers). Spectremdl features such simple optimizer, but is something like that also available in verilog-a/ams?? :D
![Smiley Smiley](https://designers-guide.org/forum/Templates/Forum/default/smiley.gif)
Would be helpful to have such a module esp. if it can treat
multiple variables, because then a simple sweep to check
all combinations is often far too time-consuming. :(
Bye Stephan
