Jul 17th, 2024, 4:28pm
how to monitor analog signal using verilog-ams (Read 2963 times)
xuedashun
Dec 02nd, 2011, 8:22am
If I have 3 analog blocks: AAA BBB CCC, AAA is toplevel block, BBB is inside AAA and CCC is inside BBB block, if these is an analog signal called as xxx in CCC, now I want to monitor the xxx signal in another block (verilogams), how to do this in verilogasm?
I know if they are digital, we can use assignment to do it
wire xxx_monitor  =   AAA.BBB.CCC.xxx;
I read the Ken Kundert's book: The Designer's Guide to Verilog-AMS, but did not find which command or function I can use in verilogams.
Could you give me some suggestions? Thank you!
Re: how to monitor analog signal using verilog-ams
Reply #1 - Dec 5th, 2011, 1:13pm
I would expect you could do
 real xxx_monitor;
 xxx_monitor = V(AAA.BBB.CCC.xxx);
but you'll have to write some kind of function to decide if the value has changed "enough" to warrant printing.  A digital $monitor isn't appropriate for an analog value, which will change by tiny amounts (every iteration of) every timestep.
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Reply #2 - Jan 17th, 2012, 5:41am
Use the absdelay event function if you're using Cadence tooling (it is a Cadence propietary extension).
real xxx_monitor;
always
  @(absdelay(V(AAA.BBB.CCC.xxx), 10m))
For non-Cadence tooling you can do the same but using the above event function:
real xxx_monitor;
always
  @(above(abs(V(AAA.BBB.CCC.xxx) - xxx_monitor) - 10m))
Cheers,
Marq
