xuedashun
If I have 3 analog blocks: AAA BBB CCC, AAA is toplevel block, BBB is inside AAA and CCC is inside BBB block, if these is an analog signal called as xxx in CCC, now I want to monitor the xxx signal in another block (verilogams), how to do this in verilogasm?
I know if they are digital, we can use assignment to do it wire xxx_monitor = AAA.BBB.CCC.xxx;
I read the Ken Kundert's book: The Designer's Guide to Verilog-AMS, but did not find which command or function I can use in verilogams.
Could you give me some suggestions? Thank you!
