Jacki
I am facing a problem with PSS simulation. The thing is that I want to run swiched capacitor circuit with PSS and PAC. The simulation is find when I use ideal switch from Spectre. When I replace the ideal switch by the real transistors, there is an error shown below and stops the simulation.
ERROR (SPCRTRF-15177): The component nfeti_rf_ahdl is not supported in PSS analysis because it is a behavior module component with hidden states. Components with hidden state are not allowed with this analysis.The PSS analysis is skipped.
I also try other models from the design kits, the same problem happens. I check the model in ADE, I think the spectre model has the highest priority for simulation as below spectre ahdl veriloga
Does anybody face the same problem before? Is it the setting problem in Cadence, or I should contact the foundry and ask for help?
Thank you!
jacki
