Sep 6th, 2024, 7:13am
about temperature coefficient of bandgap (Read 1176 times)
lhlbluesky_lhl
Dec 05th, 2011, 4:07am
i have designed a bandgap in 0.18um 0.33V process, which is the classic structure (an opamp, two bjt of 1:8, a pmos pair, and a resistor), VREF=VEB+VT*ln8/R1*R2, but the tc is 45ppm for the simulation. i used some methods to improve the tc, such as exp compensation, different type of resistors (different tc, one is positive, one is negative), and so on, but it only improves a little. in some papers, i see the compensated bandgap can have a tc of 5ppm or below, but how to achive this in actual case? or how to do curvature compensation for bandgap in real project design?
thanks all in advance.
Lex
Eindhoven, Holland
Re: about temperature coefficient of bandgap
Reply #1 - Dec 5th, 2011, 5:39am
Use trimming.
Reply #2 - Dec 5th, 2011, 9:41am
start putting offsets and mismatches into your simulation. You will see that you will need to trim and adjust the device.
Also, look up the topic "chopper offset cancellation" or "chopper stabilized op-amps" - this is one way to deal with offset issues.
RobG
Bozeman, MT
Reply #3 - Dec 5th, 2011, 11:10am
I think he wants to know how to remove the curvature (about 4 mV) from a traditional bandgap response, i.e. he wants a decent curvature correction circuit. There are countless ways that look great in simulation but they have problems over corners and mismatches which are hard to correct with a single temperature trim in silicon. Amazingly, I still see a lot of new patents popping up on this ancient subject!
IMO, the most robust are independent of the bandgap reference itself and are a piecewise linear correction. At room temp they do not change the performance (so the zero temp-co output voltage is still ~1.23 V). However at temps greater than room they add a PTAT voltage, and at temps colder than room they add a CTAT voltage.
An current mode example is published by Rincon-Mora JSSC, Oct 1998. http://ieeexplore.ieee.org/xpl/freeabs_all.jsp?arnumber=720402
You can adapt the PWL correction to the "normal" bandgap. Just inject the PWL current into the 1x pnp emitter. It might help to see how it was done in one of my patents 6,642,699
Reply #4 - Dec 6th, 2011, 2:24am
yes he wants a "curvature compensated bandgap" (search IEEE JSSC for those terms) - but the other items in mismatch and offset must be fixed first, because they are much larger than the thermal curvature.
lhlbluesky_lhl
Reply #5 - Dec 6th, 2011, 4:17am
thanks all.
RobG
Bozeman, MT
Reply #6 - Dec 6th, 2011, 6:56am
loose-electron wrote on Dec 6th, 2011, 2:24am:
I agree - that is what gets most people. He can search for my CICC paper on that too Wink
