Sep 7th, 2024, 11:23pm
How does this act as a Schmitt Trigger (Read 4564 times)
cktdesigner
India
Dec 06th, 2011, 4:03am
Could somebody please explain how the circuit in the attachment behaves like a Schmitt trigger?
Thanks.
Re: How does this act as a Schmitt Trigger
Reply #1 - Dec 6th, 2011, 10:16am
the two invertrers are not matched in size, and the feedback one is weaker.
Two inverter set up like that function as a latching structure, the flipped state, then requires a bigger signal to return to the prior state after flipping.
Therefore you get hysterisis. = schmitt trigger
cktdesigner
India
Reply #2 - Dec 6th, 2011, 8:12pm
Thank you.
could you please tell which inverter's aspect ratio will need to be adjusted to modify upper and lower swtiching points?
INVBUF or INVFB?
Vladislav D
The Netherlands
Reply #3 - Dec 7th, 2011, 9:31am
btw, what is kind of PMOS in the circut? Depletion?
Reply #4 - Dec 7th, 2011, 9:34am
cktdesigner wrote on Dec 6th, 2011, 8:12pm:
Thank you.
INVBUF or INVFB?
You have 3 inverters in a "pulling" process here, the input device (drawn at the transistor level) and the other 2.
Your hysterisis is set by the relative geometry sizes of the input device and the feedback inverter.
Its voltage division with resistors and switches, draw each of the inverters as 2 switches and 2 resistors, and think of it that way. You will start to understand whats going on better at that point.
cktdesigner
India
Reply #5 - Dec 15th, 2011, 1:08am
loose-electron wrote on Dec 7th, 2011, 9:34am:
Thank you.
INVBUF or INVFB?
I am still unable to understand how hysterisis is present.
I do not understand how the higher switching point (VIH) occurs at a high voltage value and also in the return path why does the circuit switch at a lower level voltage.
Could you please point me to a source where operation of this circuit is explained in detail?
Thanks.
Reply #6 - Dec 18th, 2011, 2:22pm
draw out the circuit as:
Ideal switches for all NMOS & PMOS elelements.
Resistors in series with those switches which model the
"on resistance" of the CMOS switch.
Look at the voltages and resistances of the system like that.
