Sep 7th, 2024, 3:15am
Help Identifying the 2 transistors on the +ve feedback path (Read 2116 times)
Larry_80
Dec 06th, 2011, 10:52am
Hello All,
Please i need some help in identifying the positive feedback path (with explanation) in the attached circuit. I will really appreciate any help....please identify the transistors in the +ve feedback path.
Regards.
raja.cedt
Re: Help Identifying the 2 transistors on the +ve feedback path
Reply #1 - Dec 6th, 2011, 10:57am
hello,
how you are biasing M5,M7? if you are generating through some constant voltage then there is no +ve feedback.
i think you forgot to connect m7 as diode connected, if so m3,m1,m5,m7 forms +ve feedback loop.
Raj.
raja.cedt
Reply #2 - Dec 6th, 2011, 11:03am
one more thing,
M6 provides -ve feedback ..
Raj.
Larry_80
Reply #3 - Dec 6th, 2011, 11:05am
Sorry, yeah M7 is diode connected and Vb is some constant biasing voltage.
Larry_80
Reply #4 - Dec 6th, 2011, 11:07am
Thanks Raja, i came up with same answer as you did, just wanted to be sure....i'm afraid of screwing up...thanx a lot!
Reply #5 - Dec 6th, 2011, 4:05pm
looks like a wide swing cascode bias circuit?
HdrChopper
Reply #6 - Dec 6th, 2011, 5:26pm
Actually thanks to m6 local negative feedback the positive feedback loop is stable, since gain is less than 1
Best
Tosei
Keep it simple
raja.cedt
Reply #7 - Dec 7th, 2011, 4:26am
but i doubt about the amount of degeneration because of it's huge value. any how i would like to ask now a days is any one using gm=1/r ckt for biasing?, because in this lower technology it may not work as we expect in theory due to lack of square law.
raj.
RobG
Bozeman, MT
Reply #8 - Dec 7th, 2011, 8:03am
raja.cedt wrote on Dec 7th, 2011, 4:26am:
raj.
I feel like I'm part of a conversation where everyone but me can see another poster's responses as I can't figure out what you folks are talking about Wink.
Raj - what sort of bias should they use? If we assume Larry's circuit is a constant gm bias (M5 is a multiple placement of M7) then it should properly bias a PMOS diff pair operating at the average current density of M5 and M7. Under these conditions the gm will remain constant over temp (well it would if a zero-tc resistor was used). I think this will be true from subthreshold to velocity sat, and to different devices such as bipolar.
Regarding the "positive" feedback path, the signal path is counter-clockwise. Assuming M5 is multiple placements of M7, at low currents the path is positive feedback. This is what you want at startup since this keeps increasing the current in the devices until the gain from M7 to M5 is reduced to 1 by the degeneration of M6. At this point the feedback isn't really positive or negative.
rg
« Last Edit: Dec 7th, 2011, 9:03am by RobG »
sushan
Reply #9 - Dec 10th, 2011, 5:46am
Hi RobG,
 Isn't at that point, the -ve f/b takes control of the loop, finalizing the current. So can it not be called as -ve f/b at the time, when current stabilizes?  May be we cannot say about the f/b involved, when M5 looses control, say it becomes linear (but this will never happen--i guess).
RobG
Bozeman, MT
Reply #10 - Dec 10th, 2011, 6:52am
Just curious, are -ve and +ve new terms being used in the textbooks? I haven't seen them before.
Analogbeginner, I suppose it can be viewed a few ways depending on your terminology. At "low" currents the loop would be positive feedback because the gain from M7 to M5 is greater than one (if M5 is multiple placements of M7 and the votlage drop across M6 is negligible). At "high" currents the voltage drop across M6 will make the gain less than one. I guess you could call that negative feedback.
The circuit will stabilize at a current where the gain from M7 to M5 is exactly 1. If a gain of more than 1 is positive FB, and if a gain of less than 1 is negative feedback, then what is the gain when it is exactly 1? It is sort of a philosophical question in my mind. Positively negative I guess  ;D
sushan
Reply #11 - Dec 10th, 2011, 6:12pm
RobG, I was thinking that at every current value, there exists +ve & -ve f/b, but whichever is predominant takes control & decides the current--> whether it is going to settle or increase, but I'm not sure, whether the point where the current stabilizes will be at a point were the gain from M7-->M5 will exactly be less than 1. I was thinking it was a relative factor, between the +ve & -ve component, which decides the current.
raja.cedt
Reply #12 - Dec 11th, 2011, 7:22am
hello analogbegnir,
may be you can  think in this way to get good idea.
The final bias point will be some where else, so whenever you are at higher bias current degeneration resister reduces the mirroring ratio and hence loop will move towards current reduction direction and if you are at lower than the final bias current, degeneration will increase the mirroring ratio hence loop will get you the final value.
Raj.
