Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Sep 6
th
, 2024, 7:17pm
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› oscillation amplitude depends on initial condition?
Previous topic
Next topic
oscillation amplitude depends on initial condition? (Read 2220 times)
vikram1977
Dec 08
th
, 2011, 2:24am
hello everybody
i am simulating a vco , to build up the oscillation i set an initial condition on a given node
my probleme is that according to the initial condition i pick, tha amplitude of oscillations change. it dosn't make any sense for me
can you help me please
is that a problem with my circuit or with the simulator
ps: i use spectreRF
regards
IP Logged
raja.cedt
Re: oscillation amplitude depends on initial condition?
Reply #1 -
Dec 8
th
, 2011, 3:43am
hello,
i am sure some thing is wrong, becaz VCO is a non-linear system hence independent of initial conditions, may be starting dynamics are depends some time. Please provide some more info to resolve.
Raj.
IP Logged
buddypoor
Bremen, Germany
Reply #2 -
Dec 8
th
, 2011, 5:08am
Hi Vikram,
the most secure and the most realistic method is
not
to use an initial condition but to switch on one of the power supplies in Tran simulation.
IP Logged
Reply #3 -
Dec 8
th
, 2011, 7:47am
Initial Conditions of a
current in the inductor
is the best way to get a LC oscillator running.
Try it, you will like it!
However the oscillator needs to settle out to a final amplitude, and that may take many thousnads of cycles of the oscillator to do so.
A trick - use the IC current in L method as described. Then see if amplitude builds or drops in transient simulation.
Adjust the current up-down till you get the right amount so its close to the final oscillation amplitude.
Speeds up the simualtion process a lot, especially with high Q things like crystal oscillators
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
