Sep 7th, 2024, 3:23pm
VCO structure suggestion (Read 5429 times)
lunren
Asia
Dec 14th, 2011, 9:34am
Hi All,
I am working on a PLL (almost every thing is done) at 912MHz. Now the customer want to change the frequency band to 2.4GHz. The preferred option is still using a ring OSC (trying to avoid inductor based VCO due to area and other concerns). I need some reference/suggestion for this time-limited design (tape out should not be delayed and I have no much time to do research and I don't have experience on such high frequency design). Any comments are welcome. By the way, here is the spec:
1) Frequency 2.4GHz
2) Quadrature output
3) as low as possible power consumption
4) 0.18um technology
5) 1.5V supply (1.8V supply regulated to 1.5V)
6) phase noise -85dBc/Hz @ 1MHz offset
Any one use Maneatis VCO working at 2~3GHz with 0.18um technology?
Lunren
Lunren
raja.cedt
Re: VCO structure suggestion
Reply #1 - Dec 14th, 2011, 9:47am
hello,
four Ring oscillator will be good enough for those specs. As far as delay cell architecture
1. Delay interpolation architecture (refer razaavi text book), but power hungry
2. J-kim cell (A Low-Noise Fast-Lock Phase-Locked Loop with
Adaptive Bandwidth Control). This gives good Phase noise and if you add biasing current, you dont see much variation of frequency with respect to pvt
3. you can use meannatis also, but i have n't worked, but what i heard through people is at lower supply voltage it is very difficult to manage.
raj.
Reply #2 - Dec 14th, 2011, 11:27am
I have used the Maneatis device with good success many times. Generally redesign the bias circuitry.
Consider running the ring oscillator at lower frequencies and using multiple phases from the ring to get the desired clocking rate.
lunren
Asia
Reply #3 - Dec 14th, 2011, 2:02pm
raja.cedt wrote on Dec 14th, 2011, 9:47am:
hello,
Which book? He has many books and I didn't find it in his "Design of analog cmos integrated circuits"? Can you give me the book name?
It seems a good one, I will do some research on this.
I am also worry about this at lower supply. At 1.8V, should not a problem and at 1.5V I am not sure. Maybe Jerry can give some comments?
Lunren
raja.cedt
Reply #4 - Dec 14th, 2011, 2:08pm
hello,
you can refer integrated analog integrated ckts book vco chapter, but as i told before it is very power hungry. At 1.5 meannatis stage will give many problems at least when you are working PVT.
raj
lunren
Asia
Reply #5 - Dec 14th, 2011, 2:13pm
loose-electron wrote on Dec 14th, 2011, 11:27am:
Hi Jerry,
Do you think 1.5V supply for a 2.4GHz Maneatis device is doable? Can you give me some hints or reference on how to use low frequency multiple phases to get higher frequency clock?
Lunren
lunren
Asia
Reply #6 - Dec 14th, 2011, 2:15pm
raja.cedt wrote on Dec 14th, 2011, 2:08pm:
hello,
raj
I got it. Thanks a lot.
Lunren
Reply #7 - Dec 14th, 2011, 4:29pm
lunren wrote on Dec 14th, 2011, 2:13pm:
Hi Jerry,
Perhaps, but it depends on the threshold voltages
of the devices.  It all scales down, but have to look at the speciifics
of the foundry process.
The poly phase method is pretty straightforward, think of it like this:
(illustrating using 9 delay cells)
Oscillator runs at 1 MHz
There are 9 1MHz square waves in your ring oscillator
Phase seperation of the 9 phases = 360 degrees/9 = 40 degrees
Take 9 clocks with 40 degrees phase difference
You have edge rates at 9MHz
Use some digital logic to combine the 9 signals to create
a signal which is 9X faster than the VCO frequency.
Thats the concept. I used this first way back in 0.5 micron CMOS
to get a SerDes system running at 2GB/sec.
We used 20 phases to get that to work with the slower transistors.
lunren
Asia
Reply #8 - Dec 14th, 2011, 9:20pm
I see. If I am running VCO at 1.2GHz, then use frequency doubler (poly phase filter + Xor works for this), I should get 2.4Ghz. The only thing I am not sure is that the two output might not be quadrature outputs. I need to check it.
Lunren
