vivkr wrote on Jan 4th, 2012, 4:41am:By the way, it might be better to use diffusion resistors rather the poly if current densities are high enough to make self-heating significant. The resistor is then embedded in a well and can dissipate more heat into the substrate directly, and any M1 cover on top of it can be placed much closer to the resistor (vertical clearance).
Yes, I believe that is the case.When you include the well and account for the spacings I'm not sure it isn't easier to make a wider poly. I guess it would depend.
Aaron, I know some models do account for self heating, but I don't know the details of how it is done.
rg
