boe wrote on Jan 5th, 2012, 2:13am:hiSkill_11 wrote on Jan 4th, 2012, 4:55pm:...
More interesting thing is that I can run this script successfully with presimulation netlist(schematic view).
But when I run the post simulation using config view, It failed.
Probably your "post" view does have a different name for R0.
- B O E
The R0 is from analogLib for measure the current purpose, not layout devices. So, for pre sim and post sim, they see the same R0. Thanks.
In addition, when I open a new CIW, and execute the script, it works fine.
But if I do something in the CIW like edit schematic, layout, simulation, then execute the script, it possiblely happened.
