Jun 30th, 2025, 8:04pm
Pages: 1 2
Regarding eye diagram (Read 18153 times)
raja.cedt
Re: Regarding eye diagram
Reply #15 - Jan 10th, 2012, 12:43am
hello YWguo,
yes you are correct. But i guess now many standards got migrated to 66b/68b to less data rate overhead due to coding . May i know what is the main criterion behind coding selection.
Raj.
Reply #16 - Jan 10th, 2012, 3:47pm
raja.cedt wrote on Jan 9th, 2012, 1:28pm:
hello jerry,
if you have coding like 8b/10b in transmitter, then data has some minimum transition so whats the purpose of RLL then?
Sorry jerry, i am new to this field so i am asking this kind of basic Questions.
Raj.
Not a problem Raj.
The 8b/10B is a RLL code.
Some form of binary data (aka NRZ data) with no restrictions (it
can have a million 0's in a row in it!) is put into an encoder,
which transforms it into an 8b/10b code structure which obeys
rules associated  with min-max distance between transitions.
The RLL code is transferred in the communication medium.
Reception of the RLL code is synchronized back to a clean synchronous
set of digital transitions which is tied to the receiver's CDR system.
That data goes through a decoder, which takes the 8b/10b and
converts it bake to NRZ data.
thats the basics.... Smiley
Pages: 1 2
