Aug 14th, 2024, 5:04pm
Verilog bus annotation using another bus (Read 1886 times)
Ohn
Jan 11th, 2012, 7:12am
I am trying to mux the n'th bit from a 256-bit wide bus, using the following method (which reminds C programming more than Verilog...):
module aaa (
input [255:0] y,
input [7:0] n,
output x
assign x = y[n];
I have 2 cases:
1. When y is [255:0]
2. When y is [199:0] (obviously, not all 'n' values are acceptable)
The above code works in simulation, though something smells fishy.
Does anyone know what is the implementation of standard synthesis tools to this block?
What about case 2 - what would happen if 'n' gets the value of 200 and above? What value will be assigned to 'x' ?
Ohn
