Jul 17th, 2024, 7:21am
Narrow Band 10 GHz Filter (Read 3099 times)
bhavuli
Jan 11th, 2012, 10:40am
Hi Folks,
I am looking for a narrow band filter with a center frequency of 10 GHz (the narrower the band the better).
Would you happen to know of any companies that sell these. I have tried Picosecond Pulse labs, Mini-Circuits,...
Thanks for this!
Best regards.
raja.cedt
Re: Narrow Band 10 GHz Filter
Reply #1 - Jan 11th, 2012, 12:26pm
try with procom. May be helpful
Reply #2 - Jan 11th, 2012, 6:01pm
Consider building your own LC network? Parasitics will be interesting
to deal with.
Also may be some SAW stuff out there, but it will have to be a widely used frequency.
Also at 10G you are sitting on the edge of cavity resonance methods are you not?
bhavuli
Reply #3 - Jan 19th, 2012, 10:48am
Thank you guys!
I found that also http://www.tte.com/ has high quality filters.
loose-electron, SAW filters are only limited to 2 GHz of operation.
Reply #4 - Jan 19th, 2012, 4:17pm
those are canned filters in boxes, you could desighn those yoursefl if you wanted.
SAW limited to 2GHz? says who?
Only available to that frequency sounds about rright.
Its a matter of what's a lucrative set of frequencies to design for.
