yixiusky
Dear all, i would like to ask one question: As we can see from schematic, there is one loop existed from output to FBP (feedback point) of the error amp.
I would like to run AC simulation to check the loop stability. However, the part in white box is discrete signal, so i need modeling it, and then i can run AC simulation.
The white part is two diode with one cap, and input to cap is pulse ^^
Do any of you have experience to do it? Or do you have any book to recommend in order to modeling it?
Thank you so much ^^
