Balthazar
Thanks JulianT. I found this Dynamic Parameter in the simulator. It works ... but only with integer values. I tried to use a variable for setting the temperature. The intention is to define a corner set, where the temperature of each corner is set by a variable (e.g. var_temp) which is used in the dynamic parameter setting of the simulator.
Example: In Corner1 var_temp = 85 and in corner2 var_temp = -40 In the dynamic parameter setup the parameter "temp" is defined e.g. at t=50us to the value "var_temp".
Unfortunately this is not working. Do you have any solution? Is it a syntax thing maybe?
Thx
