Jul 31st, 2024, 7:25am
Seal Ring in IC (Read 14478 times)
ic_engr
Seal Ring in IC
Jan 23rd, 2012, 6:37am
Hello Everyone,
I would like to get some papers or information on the importance of Seal Ring in IC Design. What does seal ring impact and what are the draw backs of not havign sealring in an IC.
I saw a link on google but does not seem to work:
www.ics.ee.nctu.edu.tw/~mdker/.../SHChen_Ker_JMR_Sept_2005.pdf
Any information is appreciated.
ic_engr
vivkr
Re: Seal Ring in IC
Reply #1 - Jan 25th, 2012, 7:58am
I don't have links to papers but I would have thought that Google would get you enough hits there.
The seal ring is used to isolate the active silicon area from the external environment, basically from humidity. If moisture creeps into your die over time, then it may cause corrosion and change impedances between the various nodes on your chip. This would be a big problem which would likely cause your design to malfunction sooner or later.
I cannot imagine any reason not to use the seal ring. There are some cases where people are trying to make a really small ASIC and cutting down the cost but even then, the seal ring is quite a small thing and it saves you the trouble of having to worry about what might happen if you didn't have it.
By the way, depending on your process and quality flow, you may not even be allowed to do anything like leaving out the seal ring.
Vivek
Dan Clement
Salt Lake City, Utah, USA
Re: Seal Ring in IC
Reply #2 - Jan 26th, 2012, 4:53am
Some companies also use the seal ring as an ESD discharge bus.
Re: Seal Ring in IC
Reply #3 - Jan 26th, 2012, 8:09pm
Seal ring usually gets tied to a lot of  substrate taps
and then ends up getting tied to I/O ring ground.
