Jul 17th, 2024, 7:43am
Looking to calculate the length of an antenna (Read 2193 times)
TurboV
Jan 28th, 2012, 12:12am
I discovered this formula which gives the approximate length of an antenna. Can anyone tell me if this is correct ? I don't have any specifications on the antenna just looking for a rough estimate.
wavelength in meters = 300 / frequency in MHz
That means if someone is using the 2.4GHz band the length of the antenna would be 300/2400 = 0.125 meters ? I don't know if this sounds correct but was hoping someone could validate this formula.
Thanks in advance
Re: Looking to calculate the length of an antenna
Reply #1 - Jan 29th, 2012, 1:53pm
amateur radio crowd has lots of stuff on this, as well as many textbooks,
Start here:
http://www.dxzone.com/catalog/Antennas/
http://ac6v.com/antprojects.htm
TurboV
Reply #2 - Jan 31st, 2012, 8:17pm
loose-electron wrote on Jan 29th, 2012, 1:53pm:
Start here:
Thanks I will check out those links.
Reply #3 - Feb 1st, 2012, 9:21pm
happy to help...
