Sep 10th, 2024, 3:13am
Decaps  in the  schematics (Read 3397 times)
zahrein
Jan 30th, 2012, 4:45pm
HI All,
When we design a circuits/schematics.  The layout  guy will certainly  put the decaps after we design it.  My question is,  what is the function of the decaps  and does it impact the performance of the design? I observe the decaps were  connected to  voltage rails.  Can  anyone  helps?
aaron_do
Re: Decaps  in the  schematics
Reply #1 - Jan 30th, 2012, 5:14pm
at RF, decoupling capacitor placement and design can be very important. The supply line connecting the supply to the circuit has some inductance and resistance which prevents it from reacting quickly to fast changes in the current drawn from the supply. Having a decoupling capacitor close to the circuit provides a large well of electrons for the circuit to draw from during transients.
I think there is a document on this website somewhere with a good discussion on supply decoupling. BTW, I said at RF because that's what I mostly work on, but I'm sure in other areas it is also very important.
regards,
Aaron
regards,
Aaron
zahrein
Reply #2 - Jan 30th, 2012, 5:37pm
HI Aaron, thanks for the sharing. now  i undertstand. Since my supply voltage is ideal, hence there is no affect on my analog  funvtions/prformance when the layout put the decaps.  We have decaps to prevent fast changes of  current drawn from the supply.
Reply #3 - Jan 30th, 2012, 9:04pm
You may want to change your power supply model a bit, put 10nH in series with .25 ohms in both the power and ground connections back to the ideal power supply.
Thats a rough set of numbers. for the bond wire interconnect and the resistance of the interconnect.
Lex
Eindhoven, Holland
Reply #4 - Jan 31st, 2012, 12:14am
Decoupling caps on reference/bias lines also help lower the noise (a result of lowering the bandwidth).
It can go wrong as well in some cases, for example when a reference w.r.t. VDD is decoupled to VSS or vice verse. Clear communication is required between designer and layouter to prevent these errors.
RobG
Bozeman, MT
Reply #5 - Feb 1st, 2012, 9:27am
aaron_do wrote on Jan 30th, 2012, 5:14pm:
Here you go: http://www.designers-guide.org/Design/bypassing.pdf
raja.cedt
Reply #6 - Feb 1st, 2012, 9:42am
hello zahrein,
when you draw switching current(or spikes ) out of supply (for example when you have big digital ckt on vdd), you will end up with voltage dip due to it's power grid resistance and inductance, so if you please a big capacitor across the vdd it supplies sudden spiky current and vdd supply dc current. Hence there is no dip on the supply.
raj.
