Sep 10th, 2024, 11:17am
Integrator circuit voltage problem (Read 3291 times)
singh
Feb 03rd, 2012, 7:30am
i am using shown integrator in a circuit which has two phase.  after 1st phase of the circuit is over, the integrator has some output (say 0.3 mV) .in the beginning of second phase , i need to provide the negative of output voltage (say -0.3 mV) to the input of integrator. how can i provide the -ive output voltage to input? is it possible to use a switch and by flipping the capacitor C1 and C2 position or just by changing their polarity using switch?
raja.cedt
Re: Integrator circuit voltage problem
Reply #1 - Feb 3rd, 2012, 9:58am
hello singh,
you forgot some input capacitor i guess, are you sure about the schematic?
Thanks.
Raj.
thomasT
Reply #2 - Feb 3rd, 2012, 10:18am
wat is this
singh
Reply #3 - Feb 3rd, 2012, 10:39am
schematic is not complete..
i just wanted to know if the polarity of feedback caps is reversed by using a switch , can i feed output with negative value to the input
raja.cedt
Reply #4 - Feb 3rd, 2012, 11:06am
no ..it's proper polarity
HdrChopper
Reply #5 - Feb 7th, 2012, 8:39pm
Hello singh,
not sure why you need to provide the negative of the output at the input of the integrator during the second phase, but for sure you cannot simply switch the feedback caps, since then you will not be holding the info from the first clock phase anywhere.
You need additional caps to perform the action you are requiring.
Best
Tosei
Keep it simple
